plumbing
harvey03
plumbing
by harvey03 » Mon Jan 28, 2008 6:13 pm
i have added a new rad to my 1 pipe system, The system runs 22mm loop with micro bore tee'd off for the exsisting radiators i tee'd into the 22mm pipe with 15mm hep to my new rad but it seems to be cold it did heat up for a bit, All the other heaters are fine. should i have used micro bore like the rest? :x
by htg engineer » Thu Jan 31, 2008 8:19 am
Using 15mm pipe, if anything would starve the radiators that are piped in 10mm.
How long did the radiator heat for ? were the rest heating as normal ?
Where did you put the tee's for the new radiator ?
in relation to the other radiators etc ?
It is currently Wed Feb 05, 2025 8:34 pm
