potterton 80 combi boiler
1 post   •   Page 1 of 1
Mark only useless
Post by Mark only useless » Fri Oct 03, 2008 9:23 am
Hi i have a pottereton 80 combi boiler it will run the domestic hot water but when you put the heating on it will fire up and run for 5 minutes or so then switch off and will start again but it will not keep running it has had a new PCB Modulation board fitted recently when you put the hot tap on the pump runs ?
