Post
by htg engineer »
Sat Mar 19, 2011 8:16 pm
E133 is a gas supply/ignition fault code.
If you have checked and replaced ignition electrode/probe, check the flame sensing probe. All OK, you need an RGI to check gas pressures.
If I had to guess, as it only happens now and again - I'd go for lazy gas valve/solenoid.
htg
