by Iron Fist »
Tue Mar 08, 2011 4:01 pm
THIS IS OFTEN CAUSED BY A LEAK SOMEWHERE IN YOUR SYSTEM TRY ADDING A LEAK SEALER INTO ONE OF YOUR RADIATORS . TURN OFF THE VALVES ON BOTH SIDES OF YOUR RADIATOR WHEN THE SYSTEM IS COLD REMOVE THE BLEED NUT ( BEST ONE TO USE IS OFTEN A TOWEL RAIL BECAUSE THESE ARE OFTEN ON THE TOP OF THE RADIATOR PIPE MAKING IT EASIER TO ADD THE LEAK SEALER ) ADD THE LEAK SEALER REPLACE THE BLEED NUT TURN THE VALVES BACK ON TURN YOUR HEATING ON ABOUT 25 DEGREES AND RUN FOR BETWEEN 4 AND 6 HOURS . CHECK THE PRESSURE AND SET TO THE BOILER RECOMENDATION . THIS MAY NEED TO BE DONE A COUPLE OF TIMES , ALL THE BEST [/code][/b]
