by rosebery »
Thu Feb 19, 2009 10:15 pm
"they teed the f&r from the boiler into 10mm microbore pipes"
Are you saying that the flow and return goes directly into microbore at the boiler? Presumably the boiler flow and return goes to manifolds so that the max run of microbore for each rad is 5m. If not I'm really surprised they actually got it balanced at all!!
Also was the system fully flushed out before before fitting and also flushed again afterwards? Microbore is notorious for clogging up and reducing flowthus reducing heat transfer.
Anyway this doesn't get away, unfortunately, from the fact that they SHOULD have installed TRVs on all rads with the exception of the one closest to the roomstat.
I still say they haven't done the job properly.
