Radiator bleed key for older radiators
Kittikat76
by Kittikat76 » Sun Oct 02, 2022 3:04 pm
Moved in to new house. Built in the 50s. Currently draining/clearing sludge from radiators upstairs. But they're old ones, different size bleed screw needed. Can someone please tell me which one I need? the valves are on the back of these single radiators. Thanks!
Re: Radiator bleed key for older radiators
by stoneyboy » Mon Oct 03, 2022 9:48 pm
Hi kittikat76,
A standard size key should be ok but you may need to file the end because some keys are internally chamfered which stops the key locating on the bleed bolt.
