All downstairs radiators have been replaced and now the one in the hall refuses to work properly.
It has been bled and water is clear so not sure there is any blockage in pipework.
System has been balanced.
All other radiators are working perfectly and all but one have TRV valves.
The hall radiator has normal valves currently wide open and near the room thermostat.
When the boiler dial is turned up to maximum all radiators get hot and this one eventually gets warm after 15 minutes
When heat setting is reduced to 3 this radiator stays cold and its inlet/outlet pipes are cold.
Have tried turning off all other radiators in order to force circulation through the hallway radiator but it stays cold and the boiler overheats up to 100 degrees.
Should the bypass valve prevent this happening?
Boiler is Worcester Bosch condensing combi .
