Radiator valves
Vinrouge
Radiator valves
by Vinrouge » Thu Aug 26, 2010 4:02 pm
Is it ok to have rad valves at an angle (not vertical) so that connecting the pipework is easier? The pipes drop down and run along the skirting but the rad is 8cm from the wall meaning 2 bends to connect up to keep the valve vertical. If it is ok will the thermostatic valve function correctly?
Regards
eggers
by eggers » Thu Aug 26, 2010 7:05 pm
yes, you can fit them horizontally
by htg engineer » Thu Aug 26, 2010 8:12 pm
Yes it will work perfectly well, but doesn't look too good.
htg
Vinrouge
Radiator valves
by Vinrouge » Fri Aug 27, 2010 1:48 pm
Many thanks for the replies.
