Radiators not bleeding properly
6 posts   •   Page 1 of 1
jamiebogle
by jamiebogle » Sat Nov 08, 2008 6:04 pm
I had a new central heating system installed a couple of years ago, and have occassionally had to bleed the odd radiator. However 3 radiators in the house don't bleed at all. When I turn the bleed valve there is no rushing off air coming out so the rads never get any better than luke warm.
Two of the rads are close to the boiler, one is downstairs.
Any help out there?
Steve the gas
by Steve the gas » Sun Nov 09, 2008 4:29 am
Only bleed rads with the system OFF.
jamiebogle
by jamiebogle » Fri Nov 28, 2008 2:35 pm
That still hasn't worked. It's almost as though there is no pressure forcing the air out of the affected rads.
The pressure bar on the combi is what it should be however.
Any more ideas?
by htg engineer » Fri Nov 28, 2008 2:51 pm
As StG says, plus what kind of system is it ?
I'd imagine it will be pressurised with it only being a couple of years old. So what is the pressure gauge reading ?
htg
jamiebogle
by jamiebogle » Fri Nov 28, 2008 3:37 pm
The boiler is a Worcester Greenstar 28i junior.
The pressure gauge reading is showing about 1 1/2 and the guide marker is 1, so there's slightly too much pressure in the system at the minute, but it always fluctuates anyway between 1 and 2 when the boiler is on, which I guess is to be expected.
by htg engineer » Sat Nov 29, 2008 12:03 pm
1.5 bar pressure is fine, very odd for a pressurised system not to refill easily.
Did you try venting the rads with the CH turned off ?
The vent may be blocked, turn off both rad valves, remove vent nipple and insert a pin into the rad vent point.
(this is in relation to other posts - this is a common fault especially if leak sealer has been added at some point, that's why i'd only use leak sealer as a last resort. Also causes problems with auto airvents)
htg
