Re-point roof ridge top tiles? what mixture to use
Skids
by Skids » Fri May 02, 2008 2:49 pm
I need to re-point my roof ridge top tiles and need to know what to use as a fitting cement.
Is it just a normal sand & cement 4:1 mix, or is there a special product that I should be using. In the new houses around the village they have what looks like a smooth dark mixture.
Thanks.
ALDA
by ALDA » Sun May 04, 2008 4:23 pm
S,
THE SMOOTH DARK MIXTURE YOU REFER TO IS PROBABLY JUST DYED MORTAR.
THE MORTAR MIX USED DEPENDS ON THE TYPE OF TILES ON THE ROOF.
BUT IN GENERAL TERMS;
5:1 SOFTER/MOULDED TILES.
4:1 CONCRETE/CAST TILES.
3:1 CLAY/FROSTPROOF.
ONE PIECE OF ADDITIONAL ADVICE IS TO REMOVE, RE-BED AND POINT UP THE RIDGE TILES AS RE-POINTING ALONE IS AT BEST A TEMPORARY FIX AND AT WORST A WASTE OF TIME,ENERGY AND MONEY AS WEATHERING WILL RESULT IN THE ADDITIONAL MORTAR BECOMING DETATCHED FROM THE ORIGINAL.
ALDA.
Skids
by Skids » Wed May 07, 2008 11:14 am
Hi ALDA
thanks for the info, as always more work !!
Regards
Skids
It is currently Sat Jan 04, 2025 10:32 am
