Really loud vibrating pipes - house shakes!
jopedder
by jopedder » Tue Jul 20, 2010 1:06 pm
Hello,
Occasionally when using the electric shower, I get a very very loud vibration (sounds like someone is drilling through the wall), which stops shortly after turning the shower off.
This has also happened a couple of times when we've not been using the water (no toilet cistern filling, washing machine and dishwasher off etc). This lasts a few minutes and is pretty scary. Vibration seems strongest on cold water pipes. The last time it happened, we rushed around the house trying to find the source - the noise was loudest in the upstrairs hall - coming from the loft above the hot water cylinder. When it has happened I've turned on a few taps in case it helps, but doesn't have an immediate obvious effect. I've found various posts on noise/vibration/humming, but this is VERY loud, you can feel the vibration in the walls, cielings, floor and door frames!!! oh, and the pump for the hot water in the airing cupboard was not pumping (but there may be a second pump with the backboiler, but I can't really access it).
Any ideas on the causes - I'm going to try and clear any potential air locks using https://www.diydoctor.org.uk/projects/curingairlock.htm tonight in case that is the problem, but I'm unsure.
Some posts have suggested the storage tank ball cock - can a fault in this really be so noisey - there is a lot of power in whatever the cause is?
Any help really appreciated - the house has been 'improved' by many a bodge DIYing boyfriends of the previous owner and has many accentricities (like we've had to have a number of sockets and the living room lights condemned after we were getting shocks! and many more).
Any help appreciated,
Thanks,
jopedder
by jopedder » Tue Jul 20, 2010 1:14 pm
further info having pondered further - :idea:
1) I recently installed a mixer tap in the upstairs bath room sink, although the noise from the shower is older (and no more frequent) and we are pretty sure that the first time it went off without any obvious cause was before I put the mixer in.
2) I've just remember that a week or so ago (not related in time to the noise) after turning the shower off it started making a kettle boiling noise and spat out hot water from the head. Hasn't happened since.
3) we sometimes put a tap adaptor onto our hose (it is one of the clamp on types) to take water from the kitchen sink into the garden. The fit isn't exact (leaks into the sink) and we sometimes use hot and cold water - could this have been a cause of getting air trapped in our system and the root of the issue? :?
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Thu Jul 22, 2010 9:26 pm
If you would like to find a reliable, insured and vetted tradesman in your area why not click through to the Find a Tradesman area of DIY Doctor: https://www.diydoctor.org.uk/find_tradesmen/ , complete the form and receive up to 5 FREE quotes
jopedder
by jopedder » Fri Jul 23, 2010 1:02 pm
thanks, i have asked for qoutes, but suspect that it is something very simple that I can sort out myself and would hate to pay a call out charge for something that I can DIY.
It is currently Sat Jan 11, 2025 12:51 am
