Hi, I need to remove 3 radiators so that I can strip and re-paper behind them. This is in a house that my daughter has just move in to so I have not had the rads off before. Am I right in thinking that I just need to turn the valves off at each end of the radiators, then drain and disconnect the rad from the valve. Replacement to be reversal of removal, followed by bleeding. One rad is downstairs and two up. Is there any order in which I should do them?
