I currently have a conventional Thorn Gas Boiler installed in my cellar and exhausted via a lining up the chimney. The boiler is rated at 100,000 Btu's and is some 25 years old. Unfortunately corrosion has taken it's toll and I have to replace the boiler. Problems -
1. I have it seems to replace with a Condensing boiler
2. The Flue (in and out) has to exit the building more than 300mm above ground level. The ceiling level of my cellar is only Approx 200mm above Ground Level.
3.All my existing pipework terminates in the cellar (Boiler Room)
4.I have no room and do not want to mount upstairs
5. I am advised that I cannot use the Chimney to take the Flue, because any new boiler will have a balanced flue
Is there a way around the 300mm above ground rule and what boiler would you recommend for a vented system
Peter
