Hi There - Just a quick query please to check that I do not have to do anything special when replacing the ball valve in my F+E Tank.
I will obviously shut off the incoming mains water at the stop cock before I start. I do not think that I need to drain the F+E tank, as the water level is quite low in it anyway.
Is there anything else that I really need to do besides undo the nuts on the old and install the new valve and adjust it. I was thinking that PTFE tape around the joint may be a good idea - is this typically done?
How much water should I allow for in the F+E tank - about 100mm?
Many thanks.
Andrew
