by Oliver_murphy »
Mon Feb 25, 2008 2:07 pm
The expansion vessel can be charged with a full system, although I dont recommend it.
Drain the system, and hold open the PRV. When its all open, a standard Schrader valve (I thinks thats spelt right, if not, a standard Bike Pump Valve) pump it up to around 1 bar of pressure. You should dip the needle on the valve first though, see if any water comes out. If you get water, you have a split diaphram, and the entire vessel needs changing.
Hope this helps.
