Resizing doors
davep
Resizing doors
by davep » Wed Aug 22, 2007 1:43 pm
Hi. How much can I safely cut off the top and bottom of a six panel interior pine door.
The existing frame is 76in high , I can only find 78in doors.
Thanks in advance
davep
Oddbod
by Oddbod » Wed Aug 29, 2007 5:42 pm
Hi. The short answer is it depends on the door! You'd probably get away with an inch top and bottom if the door is decent quality. However to be sure drill a small hole into the door downwards from the top. If you get to two inches without breaking through you're fine to take an inch off.
If you are paranoid repeat, drilling up from the bottom!
It is currently Thu Feb 06, 2025 10:25 pm
