Riello oil fired boiler not firing up.
steve072
by steve072 » Tue Jun 16, 2009 2:40 pm
Ok i think the model is RD3.Have checked power supply from timer to module(grant) seems fine.Heating cut out.Mum thought it was out of oil but i know there was plenty there.Re-start is out of action and not lighting up.
Is there a fuse on these boilers?Oil a plenty and power to unit o.k
Any help or suggestions i,d be most grateful.
Cheers S. :?
by stoneyboy » Tue Jun 16, 2009 9:58 pm
steve072,
You probably need to check the high limit stat.
steve072
many thanks
by steve072 » Fri Jun 19, 2009 7:04 pm
Had to reset thermostat.Friendly advice from friend in work.Great job.
