Ring main spur
paulhlewis
Ring main spur
by paulhlewis » Thu Jun 21, 2007 6:49 am
I would appreciate knowing what is the maximum recommended number of sockets that can be attached to a ring main using a single spur. ie can I attach a double socket followed by a further single socket?
by sparx » Thu Jun 21, 2007 9:15 am
Hi, a spur taken from the ring either from an existing skt or by a junction box ca supply ONE point only , either a single or a double socket Or a spur to a fixed appliance.
if more than the above reqd. you may install a fused connection unit (fused Spur) before/inplace of the first socket that is on the spur cable, then you can have unlimited no. of outlets run as a radial from that.
reason being the total load you can put on the spur is 13A (the biggest fuse that fits in a FCU.
regards SPARX
paulhlewis
by paulhlewis » Fri Jun 22, 2007 10:18 am
Thanks Sparx.
My local City Electrical Factors looked at me blankly when I asked for a fused connection unit: I'll try somewhere else.
Are these supplied with different amp ratings or is there just a single rating
Thanks for your reply
Regards
Paul
by sparx » Fri Jun 22, 2007 9:00 pm
Hi again Paul, try asking for a 'fused spur' the old name, they only come in one type and usually come fitted with a 13A fuse as standard, if CEF being unhelpful try any of the 'sheds', even the local general store in our village keeps them on the shelf!
regards SPARX
It is currently Sun Sep 13, 2026 3:42 am
