runnin wiring
bazza
runnin wiring
by bazza » Mon Sep 24, 2007 1:08 pm
hi guys im helping a freind run the wiring 4 sum mains downlighters in his garage just wondering if its best 2 use 1.5mm t&e or 1mm t&e as his electrition has ok'd it 4 us 2 run the wiring as long as we dont break in to the circuit also wud it be ok to run the lights on a loop or hav seperate jbs 4 the lights which wud the electricion prefer ? (only fitting 4 downlighters) ps his electricion is on holiday at moment so cant get in touch 2 ask him THANX 4 any advise bazza
by sparx » Mon Sep 24, 2007 7:32 pm
Hi Bazza,
having today installed 4 hated d-lights I can assure you the leckie will not want more than one cable(1.0mm) at each fitting so wire each one back to a J-Box with a switch wire & feed to it,
regards SPARX
bazza
runnin wiring
by bazza » Tue Sep 25, 2007 10:11 am
THANX sparx much appreciated great help cheers
It is currently Mon Jan 13, 2025 7:42 am
