self-levelling compound
Redtool_man
by Redtool_man » Mon Dec 14, 2009 11:48 am
Hello,
I want to know if I can use self-levelling compound on top of ceramic tiles. I am laying vinyl cushion floor on top so don't want any grooves or bumps that will show through the vinyl. Is there a special compound, do I need to apply something over the tiles first. CAN ANYBODY HELP PLEASE
rosebery
by rosebery » Mon Dec 14, 2009 11:34 pm
Lift the ceramics first. Remove as much of the tile addy as you can. Then use SLC to give you a level substrate.
lionelthevinyl
Re: self-levelling compound
by lionelthevinyl » Wed Dec 16, 2009 6:57 pm
[quote="Redtool_man"]Hello,
I want to know if I can use self-levelling compound on top of ceramic tiles. I am laying vinyl cushion floor on top so don't want any grooves or bumps that will show through the vinyl. Is there a special compound, do I need to apply something over the tiles first. CAN ANYBODY HELP PLEASE[/quote]
yes there is a product.its a liquid damp proof membrane.
you apply the liquid and throw a special sand on to it.when this sets it creates a mechanical key to which the levelling compound will bond.
this also guarentees that there would be no damp problems.as unlike ceramic tiles the vinyl can wont let the subfloor breathe.this way is the industry standard.but will increase floor height.
hope this helps.
regards martin floorlayer
flooring123pean
by flooring123pean » Sat Feb 13, 2010 9:05 am
The simple answer is yes. Just ensure to use the correct prima onto your ceramics and that the ceramics are well bonded.
It is currently Wed Jan 01, 2025 11:23 pm
