Hello
We're in the middle of a major (and sadly very expensive) renovation. It's a big old place with 16 rooms over 3 floors which we hope to run as a B&B. We've had a new heating system installed so that means a new boiler, 350L tank and approx 27 radiators. 3 of the ground floor rooms have underfloor heating.
We've ended up with 7 pumps and we wonder whether this is the correct and most efficient thing to do? The boiler/ tank installers fitted 2 pumps and then handed over to another firm for the installation of the rest of the system.
When the second floor radiators didn't warm up this second firm added 3 pumps from the valved off pipe work:
a) Pump one feeds Zone 1 of the heating system (front of the house)
b) Pump two feeds Zone 2 of the heating system (back of the house)
c) Pump three feeds the underfloor heating system.
The plumber says it was necessary to fit three pumps as the valves were already in place.
They say that had just the one valve left for them they could have installed just one pump, "however this would have been a very expensive option" (he didn't explain why).
Then they installed a further two pumps to:
a) Feed the hot water return
b) Feed the underfloor heating which is required by Polypipe to circulate the heat under the floor.
Does this seem the right thing to do? We're worried that what is supposed to be an energy-efficient system is going to cost us an arm and a leg in electricity powering all those pumps? Should we be worried or not?
Many thanks to all you experts out there who understand all this and can give the benefit of your advice.
