Shower Pressure Issues After Just Installing new Mixer Shower
Rob L
by Rob L » Mon Sep 10, 2018 10:28 pm
Hi. First post from a newbie. Apologies if this has been asked before. I've just had a new mixer shower fitted and the water pressure has gone from perfectly ok (if not a power shower) to being barely useable. It's not a combi boiler so the hot water is coming from a cylinder and I'm told the cold supply to the shower is coming from the header tank in the loft rather than the mains. Just doing a bit of research it seems that some mixers may be better than others or even specifically designed for low pressure. So my question is....can anyone recommend a decent thermostatic mixer shower that can work some magic with low water pressure. Any advice would be welcome. Thanks for reading . Cheers. Rob
collectors
Re: Shower Pressure Issues After Just Installing new Mixer Shower
by collectors » Fri Sep 14, 2018 9:36 am
Just before you do anything, have a check on the flexible hose to your shower head as they come with an 8/10/11mm bore. You may have a small one that is restricting flow. The other thing to do is take the flexible hose off at the wall end & time how long it takes to fill a bucket, now do the same with the hose connected at the other end.
It is currently Sat Jan 11, 2025 4:00 am
