Shower Problem
7 posts   •   Page 1 of 1
shakey
Shower Problem
by shakey » Mon Mar 16, 2009 3:42 pm
I have a Mira 88, not sure how old but at least 9 years.
I have a combi boiler system
The problem is in finding a usable temperature.
the mixer dial has to be all the way over to hot.
A tiny movement back on the dial and the shower just puts out cold water.
Sometimes it can take minutes to get an acceptable temperature.
Any ideas, please ?
shakey
by stoneyboy » Mon Mar 16, 2009 10:16 pm
shakey,
I think the mira 88 was a manual shower, try taking it apart, cleaning all internal components and resetting the spindle position.
rosebery
by rosebery » Mon Mar 16, 2009 10:18 pm
The 88 is a manual mixer. It sounds as though the cold is just overwhelming the hot. Restriction in hot feed? Blocked filter?
Or it might just need a service kit - available from most plumbers merchants.
Alternatively it might be time to consider a thermostatic valve.
shakey
by shakey » Tue Mar 17, 2009 8:47 am
Thanks for the replies, another forum said "The problem is that the 88 was not designed for use with a combi boiler"
Is this true?
rosebery
by rosebery » Tue Mar 17, 2009 7:59 pm
Yes you really should have a thermostatic mixer with a combi. Thats what I was hinting at in the last sentence of my pervious post.
shakey
by shakey » Thu Mar 19, 2009 7:26 pm
thanks rosebury, so can i just buy a thermostatic mixer and fit it to my existing Mira 88.
If so, can you recommend one, where to purchace from and its cost please?
rosebery
by rosebery » Fri Mar 20, 2009 12:27 am
No you need to replace the whole mixer assembly.
As to manufacturer Grohe are extremely good but there are so many out there on the market. You need to look at the right combination of price, specification and looks for your requirement. Actually in your particular case you'll probably be wanting to find one that has the same centres on the hot and cold feeds as your current one to avoid plumbing / tiling changes. That'll be your biggest challenge.
It is currently Sun Mar 09, 2025 11:00 pm
