shower pump
redkev
shower pump
by redkev » Wed May 14, 2008 11:38 pm
i have a combi boiler and want to put a shower pump in as pressure aint too good. can it be done? sumone told me i would need a water tank to feed the pump as a pump cant go on the mains.
plumbbob
by plumbbob » Thu May 15, 2008 8:23 am
You cannot fit a pump into a pressurised system for two reasons.
Firstly pumps are only rated between 1 or 2 bar where mains can be as high as 10 bar. The pump seals would fail.
Secondly, Pumps pump not suck. If you have low water pressure, a pump will not overcome this. It could cause all sorts of problems like air entering when a sink tap is turned on or ground water being sucked into a leaking water main.
Combi's should give an excellent shower. If the water pressure is low, you need to find out why and cure that problem.
It is currently Wed Jan 08, 2025 6:33 pm
