I have recently installed a replacement shower in my en suite.
I fitted a bottle trap (which came with the Mira shower tray). Problem is that the waste water does not flow properly. Water builds in the shower tray immediately until it is almost overflowing then the pressure seems to change and water is taken away quite rapidly until there is none in the shower tray at all. If the shower is turned off and then back on at this point the same situation starts all over again.
Is the solution to fit an anti vac trap?
any help really appreciated....
