I have an older property with a 22mm single pipe central heating system.
All radiators seem to work reasonably, but on taking up the floor near one I found the 22mm pipe had been 'pinched' (presumably with a pair of grips) between the points where the feed and returns (15mm) to the radiator T off from the 22mm pipe.
I think I can understand the physics - the water finds it easier to go straight through the 22mm pipe without 'bothering' to go up through the radiator and back down again, so the 'pinch' acts like a crude reducing valve to force more water up through the radiator.
I'm certain the floor has never been up since the system was installed in 1968, so I'm assuming the installers must have done this, and that the valves on the radiator were new at the time.
'Pinching' the pipe like this must weaken it somewhat, and I'm worried a leak might develop, and be hidden for ages until it does real damage.
I'm guessing a better way is to run 15mm pipe, instead of 22mm, between the two Ts, but is that acceptable, and might it put unnecessary strain on the pump if the radiator is turned off?
I know single pipe systems are pretty obsolete now, but has anyone installed one, and how did you get around the problem I have described in a more professional way?
Thanks for any help.
