Solid Fuel heating
melinka
Solid Fuel heating
by melinka » Sun Mar 11, 2007 4:16 pm
I have hot water but radiaters do not heat up on my solid fuel boiler, it is a Parkray. I have bled the system including draining and refilling completely. It works for about one week then fails, I have to go through all the proceedures again. It appears to have an air lock but I cannot work out what is causing it. The pump is running OK. Any ideas?[/b]
Cpt Nemo
by Cpt Nemo » Tue Mar 13, 2007 5:51 pm
Hi melinka
Are there any motorised valves which would control the flow of water between the hot water side and the radiators in your system? If so, it might be possible that one of them has a fault.
Jim
PS You can also find out more about the Weekend Plumbing course and our CH & Wiring Controls course by following the link at the bottom of each project on this site.
thedoctor
by thedoctor » Fri Mar 16, 2007 12:30 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
