Can anyone suggest the best, most cost-effective solution for a split AC system that will be used to cool one small room containing 4 or 5 computers in a rack that generate quite a lot of hot air? The size of the room would be no more than 6 sq. meters or so. The compressor would be outside somewhere, about 10m away.
It might be useful at a later stage to attach a further couple of indoor units onto the same outside compressor if possible, but I don't want to overspec too much it now in anticipation of that, as that may not be needed.
Where to buy such a solution? How much typically?
Are they easy to install yourself?
Any suggestions gratefully received
Adrian
