Switch Problem
DIYMonkey
Switch Problem
by DIYMonkey » Sat Jun 16, 2007 6:18 pm
Hi all, newbie post.
I have a dual gang switch with connections as below:
Switch 1
COM - Brown connected to switch 2 COM also 2 more Brown wires.
L1 - Brown wire.
Switch 2
COM - feed from switch 1 COM
L1 - Brown Wire
All blues are connected together - switch is plastic so all earths connected together.
I have changed the faceplate and can't now get switch one to turn on the relevant light - could someone steer me in the right direction please.
DIYMonkey
by sparx » Sat Jun 16, 2007 11:48 pm
You may have mixed up the brown wires, or done up the screw on the insulation of one core. If sw. 2 turned on does sw 1 then work? If so swap wires on sw 2 (com-L1) leave link in comms.
Presume you have 3 blues in term block?
Regards SPARX
It is currently Mon Sep 21, 2026 5:32 am
