tap change for electric unvented hot water cylinder
Simon H
by Simon H » Sat Oct 27, 2018 4:24 pm
I have an electric unvented hot water cylinder in the loft. I want to change the washer in the hot tap on the ground floor. Do I simply turn off the mains and then run the hot tap down? Then after washer change simply turn back on the mains? I'm unsure about pressure and air bubbles etc...
It is currently Sat Jan 11, 2025 3:44 am
