by ericmark »
Sun Apr 06, 2008 5:06 pm
The thermostat can have one of three main jobs.
• To turn whole central heating on and off.
• To turn central heating on when there is a danger of freezing.
• To turn central heating off when summer has arrived.
With thermostatic radiator valves often, there are no electrical thermostats, and when there is, it will be for one of the latter two functions. In both cases they are normally placed in a cold area of the house.
A frost stat will not turn central heating off, but if you turn it off at the time clock it should turn central heating on even when time clock is off.
The summer stat on the other hand should turn it off.
There is a fourth type which monitors outside temp and reduces inside temp when summer arrives.
There is also fifth type that works a zone motorised valve but with radiator thermostatic valves these are becoming less common.
So which have you got?
As to switches in programmer most have two modes one which with allow central heating without hot water and the other will not either way a thermostat should turn off central heating.
