Timed fan in bathroom not working properly
mark6167
by mark6167 » Thu Jun 28, 2007 10:57 pm
Hello everyone:
We have a timed fan in the bathroom which is linked to light switch. there is also an isolator switch. The fan turns off about 10mins after light is turned off.
Problem: Recently the fan stopped working properly. It lasts for about 6 minutes then conks out - makes noise as if it is trying to go but rotates at a snails pace.
our block of flats are about 3 years old. 6 other flats have the same problem.
Anyone got any ideas/experience of what the problem is? is it easy to fix? is there a maintenance regime we can follow to prevent problem in future?
Mark
by sparx » Fri Jun 29, 2007 3:31 pm
Hi Mark, it's knackered! cheap fans only good for abt 3 years, bushes on shaft dry out, rust, then when running warm up & almost sieze.
I have taken them out, cleaned, lubed, replaced, last a few months.
budget for replacement every 3-4 years ,sorry that's life of modern kit,
regards SPARX
mark6167
by mark6167 » Fri Jun 29, 2007 7:52 pm
Hello Sparx
Thanks for that. The fans are made by Electromecanicas MC, SA (Spain) and they seem quite sturdy. They are centrifugal fans serial number RF2C-133/046 K010.
Sorry, link deleted, no external advertising allowed.
Do you still think they only last 3-4 years? If so, i guess it is just a question of replacing whole unit - that shouldn't be too difficult should it?
Mark
It is currently Sun Jan 12, 2025 3:58 am
