Toilet attached to pump system in Bathroom?
chambers
by chambers » Sat May 29, 2010 9:25 am
I have recently had a new bathroom installed along with a pump to cover the bath, shower & basin, the problem is that the plumber has also attached the toilet to the pump system (we have another bathroom with similar setup but loo not attached to pump) This means each time the loo is flushed it sounds like a macerator loo and is rather noisy. Should the loo have been attached to the pump? Is it possible to detach it and have it work separately from the rest of the bathroom?
by htg engineer » Sat May 29, 2010 4:26 pm
Well is it a macerator ?
It must be - there'd be no other reason to connect to a pump.
htg
chambers
by chambers » Sat May 29, 2010 6:26 pm
Thank you for reply but no, it isn't a macerator toilet, it is a normal wall hung one attached to a hidden Grohe cistern. Is it fairly straightforward to disconnect from pump?
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Thu Jul 22, 2010 9:45 pm
If you would like to find a reliable, insured and vetted tradesman in your area why not click through to the Find a Tradesman area of DIY Doctor: https://www.diydoctor.org.uk/find_tradesmen/ , complete the form and receive up to 5 FREE quotes
It is currently Sat Jan 11, 2025 12:43 am
