Toilet siphon flushing much less water now
Jim Carrey
by Jim Carrey » Fri Oct 20, 2023 9:32 am
Hello!
I was checking something in the toilet cistern. I flushed, but holding the float ball, so the cistern wouldn't be filled. With a very low level of water in the cistern, I flushed a couple of times. Then I let go of the float ball and the cistern was filled.
I didn't do or change ANYTHING.
The problem: Now, when I flush, the siphon stops the flushing at a much higher level than before, flushing much less water than before. The flushing now stops every time at the hole you see on the picture. Before, it was stopping at one of the holes on the left (that is, at a much lower level).
Again: I didn't change ANYTHING. The hole the arrow is pointing to has always been unplugged.
Was it bad that I flushed without the siphon being covered with water? How can I make the siphon go back to flushing normally (that is, almost emptying the cistern)?
Thank you!
Re: Toilet siphon flushing much less water now
by stoneyboy » Sat Oct 21, 2023 10:46 pm
Hi Jim Carey,
Presumably you are holding down the cistern lever to obtain a full flush, otherwise You will have to remove the plunger and see if the seal around the shaft on the top of the diaphragm is in place/intact.
It is currently Sun Sep 13, 2026 4:28 am
