Plumbing in a washing machine
MrBear
by MrBear » Fri Apr 04, 2008 1:20 pm
We are fitting a new kitchen soon where the sink and washing machine will be in a different location. I am working on modifying the supply pipework accordingly.
I have created a new branch from the rising main to where the cold tap will go and part way along this branch I have put an appliance valve T piece as per the instructions in the 'Plumbing - Washing / Dishwasher' project.
It occured to me last night that as a result of this setup there is no non-return valve to stop water flowing back from the washing machine.
Is what I have done ok and not worth worrying about?
Thanks.
MrBear
by MrBear » Fri Apr 04, 2008 7:40 pm
Sorry, should have said that the appliance valve was for the washing machine if that wasn't obvious.
nitro23456
by nitro23456 » Fri Apr 04, 2008 10:13 pm
put in a non return valve.
by htg engineer » Sat Apr 05, 2008 9:28 am
Alot of washing machines have non-return valves built in - check manufacturers instructions.
Plus in the washing machine there's no way the dirty and clean water could mix - the filling of the washing machine is through the drawer.
Non-return valve are sometimes fitted to the waste to stop other appliances such as dishwasheres pumping food and dirty water into the washing machine.
It is currently Mon Dec 23, 2024 6:33 am
