cold water tank
7 posts   •   Page 1 of 1
marcpaul
cold water tank
by marcpaul » Wed Apr 09, 2008 9:08 pm
hi all
just insalled a shower cubicle complete with a 2 bar pump. hot water is fine but having problems with the cold....you cant connect mains pressure to the pump so i need to put a tank in the loft but i cant get a tank that fits through the hole.can i butt 2 or 3 smaller tanks together... or can i buy a device that will reduce the cold pressure to the pump. cheers
Rico
by Rico » Thu Apr 10, 2008 11:05 am
Marc,
What kind of hot water system do you have.
Conventional, combi, unvented.
Rico
m d cooper
cold tank
by m d cooper » Thu Apr 10, 2008 1:48 pm
you can get a coffin tank to fit in the loft
marcpaul
by marcpaul » Thu Apr 10, 2008 7:00 pm
hi rico
my water system is ..a back boiler with a hot tank in the airing cupboard with a small cold tank on top that feeds the hot tank
many thanks
marc
m d cooper
by m d cooper » Thu Apr 10, 2008 7:42 pm
you can get a tank at screwfix,i have 1 in my loft for topping up the hot water cylinder
marcpaul
cold water tank reply
by marcpaul » Thu Apr 10, 2008 8:27 pm
hi rico
its a bog standard system... back boiler, hot water tank in the airing cupboard with a cold feed tank on top of it. i know i need a supply tank in the loft for the shower but i cant get a standard size tank up there. i was wandering if a pressure relief valve would do the trick if i connect the mains up to the pump, and turn the pressure down.
many thanks
marc
Rico
by Rico » Fri Apr 11, 2008 11:52 am
Marc,
What exactly is the problem with the cold. I'm assuming it is overpowering the hot.
Maybe the easiest way to sort would to check the pressure of your cold mains supply and get a matching pump for the hot.
Rico 8)
It is currently Sun Nov 24, 2024 4:38 am
