Stud partition wall at 90 degrees to exposed beams
space refurbs
by space refurbs » Fri Apr 11, 2008 6:49 pm
Hello,
Does anyone have any experience of building a drywall partition at right angles to ceiling joists, when the exposed ceiling beams have to be retained (as a condition of listed building consent).
It will need to be part E compliant and I'd prefer to use steel framing.
I'm assuming I can just screw the u-channel head track to the upstairs sub floor between the joists, use a piece of c-stud on the vertical sides of the joists and a small piece of u-channel on the underside of the joists to get a sort of 'wraparound' effect?
Joiner_Mike
Ceiling
by Joiner_Mike » Tue Apr 22, 2008 11:12 pm
I would just build the partition wall as if the bottom of the exposed beams are the ceiling. then fix a c section part inbetween the exposed beams so it still suports all the outer edges of the plasterboard.
It is currently Sun Nov 24, 2024 5:28 am
