wireing wall lights
gdh82
wireing wall lights
by gdh82 » Mon Apr 14, 2008 8:57 pm
hi im looking to put two wall lights up this week before i paper the wall as obviously i want to hide the wires.
i have a fairly good idea what to do but would like someone just to go over it.
i have a double socket close to the wall where i want to put the light.
cheers
BLAKEY1963
Re: wireing wall lights
by BLAKEY1963 » Mon Apr 14, 2008 11:19 pm
[quote="gdh82"]hi im looking to put two wall lights up this week before i paper the wall as obviously i want to hide the wires.
cheers[/quote]
gdh82
personally i would rewire back to mains board and form a new separate circuit.
however if socket is on the ring ( presume u have checked 4
continuity of conductors to prove ring ) then a spur ,fused
preferably with neon can be added to ring main ( still being kept
on the ring ) . on the load side 1.5 LIGHTING CABLE , can be run to feed the wall lights. i would recommend a 3 amp fuse in the spur
get a electrician to check over your work
BLAKEY1963
gdh82
by gdh82 » Fri Apr 18, 2008 11:32 am
Can i run two lengths of wire,one for each light from the same spur?
It is currently Fri Nov 22, 2024 4:04 pm
