Damp Proofing! Request for advice
dhsingh
by dhsingh » Mon Apr 21, 2008 8:49 pm
:oops:
Could somebody please advice whether it is essential for DPC in the brick work should make one continous layer with the DPM of the floor/oversight?
If these two (DPM & DPC) are seperatly laid (but approximated by cement) this will allow damp or not
Any advice will be greatly appreciated!
ALDA
by ALDA » Fri Apr 25, 2008 9:01 pm
DHS,
BRIDGING THE GAP WITH MORTAR WILL ALLOW DAMP/WATER INGRESS.
IF I UNDERSTOOD YOUR POST CORRECTLY, YOU NEED TO JOIN ANOTHER CONTINUOUS SHEET/DPM TO THE EXISTING DPM THAT WILL ALLOW IT TO BE EITHER LET IN UNDER DPM/MORTAR JOINT AND/OR JOINED.
THESE JOINS CAN BE ACHIEVED BY USING BITUMIN MASTIC APPLIED CONTINUOUSLY WITH A CARTRIDGE GUN.
ALDA.
It is currently Mon Dec 23, 2024 12:15 pm
