shower mixer bath tap
muttley
by muttley » Tue Apr 22, 2008 8:52 pm
Does a medium pressure bath shower mixer ,mean it can use mains cold water with low pressure hot. thank you
rosebery
by rosebery » Wed Apr 23, 2008 8:27 pm
Whether it does or not it won't work properly with unbalanced pressures between hot and cold.
You either need a separate cold feed from the CW storage tank so that hot and cold are at the same pressure OR fit a pressure reducing valve in the existing cold mains feed.
Alternatively you may have a combi boiler in which case both hot and cold will be at mains pressure anyway.
Hope that helps.
It is currently Sat Nov 23, 2024 12:57 am
