Light Bulbs Make Ringing Noise?!
OPeter
by OPeter » Thu May 01, 2008 4:40 pm
I have 2 recessed lights that are on a dimmer switch.
Can anyone tell me why they make a high pitch noise when I turn the dimmer down? They are standard recessed 65W bulbs.
Thank You
by ericmark » Fri May 02, 2008 9:56 am
Read "Flickering light" post similar problem.
markouse
by markouse » Tue May 06, 2008 8:00 pm
probably a cheap dimmer. the triac in the dimmer switch causing the elements in the bulbs to vibrate due to the magnetisation of the filament from choppy voltage spikes from the triac. buy a better dimmer!
hope this helps.
It is currently Fri Jan 17, 2025 10:11 am
