Stainless steele chimney/cooker hood question
vw754
by vw754 » Tue May 20, 2008 9:41 pm
Im going to install a chimneyhood above my gas cooker,on the same wall rite at the top there are 3 pipes running along the wall.
Problem is i cant extend the chimney (cooker hood) to the ceiling as the pipes come in the way.......Does this cause a problem? Does the hood have to be rite up to the ceiling?
Ive had a ducting put in so the chimney will be using a outside vent.
stevenc1603
by stevenc1603 » Wed May 21, 2008 1:41 pm
The ducting will need to connect to the chimney hood its self so as long as you can get that connected it will function OK.
Asthetically, the chimney should be from the top of the wall at ceiling height all the way down. You can push it up and connect it to the wall below the pipes but there will be a gap around the top that will look bad.
gillyroo
by gillyroo » Tue Jun 10, 2008 11:07 am
If you have a wall unit each side of the chimney hood, you could run a panel across to connect the two (a 'flyover') and finish the hood at that point. Run cornice all the way along to finish off. 8)
TheDoctor5
by TheDoctor5 » Tue Jan 20, 2009 10:10 am
It is currently Mon Nov 25, 2024 6:01 pm
