coving between tiles and bath
jonna
by jonna » Wed May 28, 2008 8:20 pm
what is the best way to stop the leak under the plastic coving
will I have to replace the bottom row of tiles and then replace and
use silicone?
plumbbob
by plumbbob » Wed May 28, 2008 9:52 pm
These trims are such a pain, they leak so often, and they are almost impossible to repair. Water and mould gets trapped under them and nothing will create a good seal.
For a better seal, ensure the bath is firmly fixed to the wall, tile down to the bath leaving only a 3mm gap between bath and tiles. Fill the gap with a generous bead of silicone.
If the seal ever fails, cut out, clean, replace with new silicone. Job done!
It is currently Tue Jan 07, 2025 2:13 am
