Gas Fire and surround
hippomania
by hippomania » Sat May 31, 2008 7:31 pm
Have just bought a new gas fire & surround and was thinking of putting the surround up ourselves, however am unsure of whether this is advisable and also what needs to be fitted first - fire or the surround?
Surround is Jurastone, so if it can be fitted by ourselves what is best product to use to fix it to the wall as obviously I don't want it falling off!!
Your advice is appreciated
Ian
by htg engineer » Sun Jun 01, 2008 8:54 am
It depends on what you have at tghe moment, if swapping a like for like fire putting surround up first shouldn't be a problem.
If catchment space needs altering or flue liner needs to come out, putting the surround and back panel up first makes it awkward to work. If you're fitting a marble back panel then it needs to be sealed properly to prevent any fumes escaping up the back and coming back into the room.
htg
hippomania
by hippomania » Sun Jun 01, 2008 9:37 am
Is there any specific sealants needed to fix surround to wall or can i just use no nails or a product like that? or would it be better to get a proffesional in to do the job?
cheers
It is currently Sat Dec 28, 2024 11:44 am
