Problem with cold water tank filling
chalkie99
by chalkie99 » Tue Jun 03, 2008 8:00 pm
Hello,
Any help appreciated please!
We recently had a problem with an overflowing external waste pipe due to a faulty ballcock in the main tank in the attic.
a new ballcock was fitted by a friendly plumber and all seemend well.
However, we have now noticed that the tank is filling about every 10 minutes as water seems to be constantly draining from the tank even though no appliances are being used in the house.
We have checked the tank and it is not overfilling, there are no dripping taps, etc and no overflows are leaking.
Everything in the attic is dry as is the airing cupboard which houses the immersion heater so we are absolutely at a loss to work out where the water is being lost.
Any ideas please?
Thanks in anticipation.
nitro23456
by nitro23456 » Wed Jun 04, 2008 2:41 pm
the water must be going somewhere!
you dont have a toilet constntly overflowing into the pan do you?
Dylfin
by Dylfin » Thu Jun 05, 2008 10:10 pm
Hi, are you sure the cistern is filling and it isn't the open vent pipe discharging due to cylinder overheating?
cpm
by cpm » Sat Jun 14, 2008 3:04 pm
hi,
Is the cistern constanly filling?, if so, being that no tap or overflows show any signs of water you may have a hidden leak!!!!
I hope you find the problem
yours,
cpm
It is currently Sat Nov 23, 2024 1:18 am
