Shower needs to drain up hill
jardov
by jardov » Sun Jun 08, 2008 8:00 pm
I'm installing a shower into our basement and need to lift the water - what's the best way to do this? The building regs guy suggested draining into a sump built into the garden and then use a sump pump to pump it into our nearest drain. I was wondering whether or not there was a macerator type solution with which I could lift the water internally and then direct to a suitable drainage point.
thanks
J
by htg engineer » Mon Jun 09, 2008 5:34 pm
It is currently Mon Nov 25, 2024 11:14 am
