newish floorboards
wonza
newish floorboards
by wonza » Thu Jun 12, 2008 9:45 am
We're thinking of using our current floorboards instead of buying laminate.. they really dont look that bad, but may just need a clean.. is it likely I should still sand them down? or can I get away with just cleaning them and varnishing?
Thanks!
Woodfinish_Man
by Woodfinish_Man » Fri Jun 13, 2008 1:58 pm
The risk with just a quick clean and then varnishing over the top of an existing coating is that you may encounter a compatability problem.
It's definitely worth trying to clean the surface (on a small inconspicuous area) and then apply 2 coats of a Waterbased Coating such as Aquacoat SP or Natural Finish Floor Varnish. After 5 days take a coin and rub it over the surface, if the coating is stable and doesn't flake off then you can proceed and do the whole floor.
Hope this helps.
Woodfinish Man
It is currently Wed Nov 27, 2024 3:18 am
