jambs on door liner not straight...
gaurya
by gaurya » Thu Jun 12, 2008 5:23 pm
I am trying to install a door liner. But, the jambs on the door liner are not straight. They are very bent and therefore i cannot get a straight finish. I am just wondering whether this will cause a problem when fitting the door? or do I give the door liner back and get a new straight one?!
Joiner_Mike
Door Lining
by Joiner_Mike » Fri Jun 13, 2008 10:33 pm
The door can be shaved to any shape (within reason) but i will still recommend u take it back and get it replaced with str8 wood. No point in making the job harder for yourself. Don't forget if you don't get it right now everytime you wanna change your door you will have to go to the extra trouble of shaping the door again!
gaurya
Re: Door Lining
by gaurya » Sat Jun 14, 2008 1:35 am
[quote="Joiner_Mike"]Hi
The door can be shaved to any shape (within reason) but i will still recommend u take it back and get it replaced with str8 wood. No point in making the job harder for yourself. Don't forget if you don't get it right now everytime you wanna change your door you will have to go to the extra trouble of shaping the door again![/quote]
Thanks for the reply.
I have exchanged the door liner set for another one but that to is the same...not as bad as the other one. I bought it from homebase. I was wondering if it was better if I got the door liner set from a timber merchants?
plumbbob
by plumbbob » Sat Jun 14, 2008 1:02 pm
I wouldn't hold your breath about the timber merchants, I have bought some frames over the years as bent as a nine bob note.
I think the least best place to buy is a DIY store as the wood is constantly heated and cooled in a dry atmosphere.
Best place is as you say a timber merchants or I usually but from a good builder's merchant.
Joiner_Mike
door lining
by Joiner_Mike » Wed Jun 18, 2008 11:30 pm
Again take it back.
You will probably be better going to a timber merchants as they specialise in timber they have more knoweldge in storing materials correctly. But some have a tendacy of trying to get rid of the bent ones. So go in and pick your own. Sight the wood before you pay for it. If it looks bent tell them to get you a straight one.
It is currently Tue Jan 07, 2025 6:32 pm
