WALL SOCKET SWITCH PROBLEM
Linhombre31
by Linhombre31 » Fri Jun 13, 2008 6:38 pm
Occasionally one of the switches on a double wall socket I use for telephone and PC connections won't switch "off", despite a few tries. There's also an intermittent spark from the switch. Is this a repairable fault, or should I play safe and replace the socket? PS The switches are of the modern "rocker" type.
kbrownie
by kbrownie » Sat Jun 14, 2008 4:27 pm
Hi Linhombre31,
Easiest solution is it change it, the pivots inside switches sometimes do break or damage making it hard to switch.
KB
Linhombre31
by Linhombre31 » Sun Jun 15, 2008 12:24 pm
Thanks. I did wonder whether it was a "wear and tear" problem, and will replace the socket.
It is currently Thu Jan 30, 2025 12:35 pm
