Break in Neutral wiring on ring main
davidbee76
by davidbee76 » Sat Jul 12, 2008 12:17 pm
I've got a break somewhere in the neutral wiring of my ring main. I've checked for any loose wires in the sockets. How do I find out where the break is without employing an electrician who wants to charge me by the hour to find it? Thanks for any advice.
BLAKEY1963
Re: Break in Neutral wiring on ring main
by BLAKEY1963 » Sun Jul 13, 2008 6:51 pm
[quote="davidbee76"]I've got a break somewhere in the neutral wiring of my ring main. I've checked for any loose wires in the sockets. How do I find out where the break is without employing an electrician who wants to charge me by the hour to find it? Thanks for any advice.[/quote]
DAVIDBEE76
U need a continuity tester , a low omh rated omh meter, to
test between the neutral conductors.
if u test end to end of neutral at any one point then a low
reading of say 0.50 omh should be obtained .
testing from point to point will find the fault.
NO disrespect this is normaly done with proper equpment
by trained personel.
u need to follow safe isolation proceedures and turn off
the mains while doing any dead testing.
if u do not possess the item of equipment needed , u need
to get in your electrician .
BLAKEY1963
It is currently Sat Jan 18, 2025 3:06 am
